o2 sensor, im on #3 in 2 months WTF?
justinl4322
raleigh
i keep throwing O2 sensors and cannot figure out why. ive replaced them with 2 different kinds and they still keep going bad. what would be causing this problem? how can i fix this?
any possibility you are loosing coolant / antifreeze ? if there is head gasket issue or crack where you are possibly burning coolant it will take out an O2 sensor ( and a CAT ) in short order.
Just one possibility of many, what kind of vehicle we dealing with ?
honestly it might not even be the o2, have you had a repair shop diag this not just pulling codes.... what is the code #
I could see what AllData at work may say... would need year make model of car
its a 97 TJ. im not losing coolant. the code is reading that the air to fuel mix is running rich. i think its code 55.
What is your fuel pressure? That is the most common cause of air fuel ratio too rich or too lean. Also a cracked exhaust manifold can cause it too.
