C.Berry
Bad News
- Aug 10, 2008
- Blacksburg, Va
99 burb 2500 new fuel pump has idle pressure around 52-55psi, wot makes it to 59psi but still has hesitation on hills and from stop! Put it on live stream scanner and o2 sensors were all over the place showing diff readings from .200-.840 I'm assuming volts!? is this normal?scanner says I have codes for o2 sensors but no cel on dash! Any other computer or sensor able to make o2 to seem bad? Thanks trucks running great just no get up and go unless ya 3000rpm into it!
