Cherokeekid88
- Jun 30, 2007
- High Point, NC
I am looking to buy a decent code scanner. What do you guys reccomend....I don't want anything fancy, but nothing crappy.
Do u have an android phone? If so u can download a free app & get a Bluetooth adapter
Sent from Mobile Command Center
Yeah I have the torque pro and it reads everything a traditional scanner would and more. Works great, and i'm fixing to load it onto a tablet so I can have full size gauges going down the road. I have $35.00 in it. For that cheap its worth a shot.Do u have an android phone? If so u can download a free app & get a Bluetooth adapter
They all hook up through the obd2 port.....I would also like to know a little more about the app scanner...I haven't even thought about that....How does it connect to your specific car though?
Sent from my DROID BIONIC using Tapatalk
Vgate v1.5 Mini Small ELM327 OBD2 OBDII Bluetooth AdapterWhich bluetooth adapter are you using Hano?
I was intending to say that I have $35.00 in the app and the bluetooth adapter. So no tablet for $35.00...and if they made one I probably wouldn't want itwhat tablet are you using for $35?
The launch scanners at $169 are the best bang for the buck right now. Color graphing of up to 4 things(iirc).
There is an additional free plugin for the torque app. called torque scan, it gives pretty much every reading you can think, from rail pressure, fuel trims, o2 sensor data, closed/open loop, fuel pressure, manifold temp etc.etc. it depends on what features you have available for monitoring in your ecm. Plugging it in my diesel gives me a different set of readings obviously. For less than 40.00 its pretty trick. Yeah its not a $5,000 scanner, but I was able to single out the faulty O2 sensor to the exact sensor, versus just a bank. Its not a bad app.I have already played around with what I can access on the app....looks promising. My adapter should be here Monday/Tuesday...as soon as I get it, I'll try it out and post up.
