criket
Blue Ridge 4x4
- Aug 18, 2010
- Dobson, NC
I'm going to post up a few upgrades/repairs that were performed on my buddy Ricky's jeep (obxbronco on here). I hope he doesn't mind.
A little background on the jeep
2001 Jeep TJ Sport
4.0 liter
Stock gearing and axles.
What looks like a 4" lift but unsure of brand (everything is painted black underneath)
33" Duratracs on American Racing wheels (I think)
Well, my buddy with his TJ has some work he wants to do to it. He doesn't have a garage so we are using mine. Works out great because I get some wrenching time
Here is the list of repairs/mods:
- Freeze plugs. We think one has come loose on the back of the motor and is leaking through the bell housing. So we gotta pull the motor.
- Rear main seal
- Valve cover gasket
- Oil pan gasket
- Upgraded track bar
- 1.25" body lift
- 1" motor lift
- And whatever else.
We started on Saturday around 12 noon. Here are some pictures.
Not a lot done to it since I'm only working on it about an hour every couple of nights this week. We got to cut the exhuast and unplug the computer connections and she should pop right out.
Oh and if you guys don't have one of these and need to disconnect a fuel line or AC line, get one! Fuel line came off within 3 seconds with this tool.
2001 Jeep TJ Sport
4.0 liter
- Rear main seal
- Oil pan gasket
- 1.25" body lift
- 1" motor lift
After topping it off with oil and coolant, I went to start it and it did nothing. After checking the battery and uses, I began following the wires and found that one of the grounds on th eblock had a nut loose. I tightened that bad boy down and she started!!!
