willp728
- May 27, 2015
- Fuquay Varina
I have a 1966 F-100. It has a pretty warm 460, C6, NP205, 9" & D44. Not sure if any of that matters for this, but there it is. The ignition system is a Mallory unilite distributor, MSD 6A box and parts store coil. The fuel system id a Summit Racing mechanical fuel pump and holly 750.
Now to the issue, When starting the truck cold, could be a few hours to days, it fires right up, I let it warm up and take off. After about 5 minutes of driving it cuts off, and is a bit of a pain to get to re-fire, but not too bad, 2 cycles of pumping the gas and holding the key for about 10 seconds, but fires back up and runs fine. About 1-1.5 minutes after that fun exercise it does it again, but re-fires after a little trying. About another 1-1.5 minutes after that it cuts off a third time, and the same process repeats, but it does fire back up. Runs like a champ after that. It's like clockwork, it will stall 3 times every time. I have a glass fuel filter right before the carb, and when it stalls there is gas in it, so I'm not sure its emptying the bowls and filling them back up, and I don't know how it would do this exactly 3 times and then be fine. Any ideas? I'm out of them
