jdcarnathan
- Jul 22, 2007
- Charleston
what is a decent pair of offroad lights, i want bright and would like to be pretty cheap, i dont care if they are used, i will trade a bumper i have for some
Those baja lights are a waste of money. If your gonna get some lights, at least hold out to get some decent ones. Like hella, got a pair of those and they are more than enough. Rugged and long lasting, and can turn night into day.
So Fog Lights and Driving lights, whats the real difference here?
Is it a good idea to have a pair of both on your rig if your looking for the best in road driving lights?
Why are they a waste of money?
I've got 4 on my roof and they light up PLENTY, I've gotten lots of comments about them and they are tons better than just stock lights. More than enough light for the trail.
Sure they're not hellas but all 4 cost me $40 and the time to run the wiring. Makes driving on forest roads and gravel roads at night a ton better and safer.
Guess the illumination that they throw out is imaginary and I should save up and get some "real" lights...
Actually the color ofthe light is not the difference. The real difference between the tow is that a fog light has a shield around the bulb so that only light off the reflector gets out. Fog lights look cool, but unless you're in a fog prone area, don't do a whole lot. They spread the light in a wider pattern bit not much for distance. Also only to be used with low beams. Driving lights shoot light further down the road to look for animals pedestrians ect. Only to be used with high beams.So Fog Lights and Driving lights, whats the real difference here?
You can get the Baja lights from walmart with wiring, switches and fuses all in one box for like $15. They work well enough and it's walmart so you basically have lifetime replacement.
Is boone what you'd call a fog prone area (or the 321 to get to boone from Hickory)?
Never been to Boone... I hear there's nothing there except ASU.Is boone what you'd call a fog prone area (or the 321 to get to boone from Hickory)?
