Offset Ball joints for a tj negative camber problems
jeepyj1129
wheeler
rock hill SC
Any one used these before just got done doing a wj steering swap on my 04 rubicon and noticed that I have some negative camber on driver side I just put new ball joints and new unit bearings on it so there aren't any worn out parts was just wondering if any one else has had camber problems and how u fixed yours
The axle tube is probably bent. A buddy has a TJ Rubicon and his front and rear are both bent.
The housing is probably bent. Let me know if you want to look at checking it out and repairing it without using those ball joints.
Yea I assumed it is bent didn't know if there where any other ways to fix it besides offset ball joints
Do y'all have a way to bend it back
It is out about 2 degrees I can add gussets and what not was probably just going to add a truss how much to bend it back and a full alignment
Yep (depending on how bad and where it is bent) we have done them before. Typically we add tube sleeves and gussets once we get it back into place.
Send me a pm with price
