mommucked
Endeavoring to persevere
- Sep 26, 2011
- Rural Apex n.c.
I do oil changes in my driveway (gravel) I use ramps and a large, open plastic pan w a spout. I save large pieces of cardboard from work to lay on and slide under the vehicles .I wear nitrile gloves to keep the oil off my hands. The oil in a hot engine can be too hot for the gloves and I've about burned my finger/thumb removing the loose plug.I used to get the plug out and instantly remove the glove w the hot oil on it. I've saved old cotton tshirts and socks for rags for years. I recently had a bag of them ready to do 2 oil changes and I had an idea............I put an old sock over the nitrile glove on my hand and removed the hot plug. The sock kept my fingers from the heat of the oil and the hot plug as I unscrewed it. While the oil drained I grabbed the hot filter and unscrewed it w the sock still over the glove. The sock insulates the heat from the hot filter and gives a good grip on the filter, even if it's got oil on it. Pull the sock off and wipe the glove off w it and the glove can be used again to install the plug/filter when the oil has drained. I pull the gloves off and blow them back inside out to use them again and not get any oil on my hands.
