kilby
Member
- Mar 17, 2005
- Charlotte, NC
Friend has a Yota P/U that's just developed a pretty good oil leak "somewhere" on the motor. I can see there's oil mostly on the driver side of the motor towards the front. It's definitely not leaking from the valve cover, but it is leaking quite a bit. Enough to kinda spray a little around the engine bay when it's driving and leave a little puddle in the parking lot.
He said there was a pulley seal or something like that the PO had replaced recently. Does anybody know if there's an oil pump or anything like that that could be causing a leak? Any other seals/gaskets I should check out?
I don't know Toy's very well, so if you need more info, post up & I'll get him to answer whatever questions.
