YJJPWrangler
- Jul 19, 2005
- Charlotte
Motor in question is a 1991 4.3L Chevy. I need to remove the existing oil pickup tube and replace it with a shorter version so I can use a high clearance oil pan. These pickups are pressed into the pump. I have seen a tool that slides around the shaft of the tube and you can then hammer it out. Any idea on where to find one? Or does anyone have a better suggestion for removal? The motor is on a stand so I have full access to everything.
new one should have been snug going in. If it wasn't, worry about it, green loctite unless someone knows a better sealant.. personally never had any trouble as long as it took a few hammer bumps to seat into the pump and no rotation of inlet pipe after insertion -- even when reusing pickups. Friendly reminder - drill prime the pump if possible.. if not, disable ignition/fuel system and turn over until oil pressure comes up. And of course assembly lube ftw.
