oil pressure sensor broken
98zjstroker
concord nc
I just finished up an oil change on my ZJ and broke a sensor off.....whoops. it goes directly into the same place the oil filter bolts on to and I believe it to be the oil pressure sensor (due to my car running but the oil pressure gage not working now). the jeep started just fine and ran without an issue. butt I did not drive it anywhere. is this indeed the oil pressure sensor? and will this cause any problems with the motor? i.e. does it affect the actual oil pressure or cause problems if I drive it for a few days till I can have it fixed? thanks for the help
ive attached two pictures showing the sensor. it has a orange ring on it so you know which one
