iwaxmyjimmy
College Web Wheeler
- Mar 10, 2007
- Greenville NC
So I've got a k5 that I've slowly been building over the last few years. I've got 60 psi at the sending unit by the filter. Priming the oil system I'm getting oil out if the lifter bores. With lifters in, valves lashed no oil out of the pushrods and I've verified the the pushrods are clear. I've rotated the engine some by hand and continued priming and nothing out the pushrods.
I first noticed it when I started it up and had some valve noise after putting the roller cam in it I didn't have a few valves lashed. Well when I popped the covers not much oil on the rockers. Tight end the rocker arms more started it up, had a high idle that was a vacuum hose undone. Connected it idled fine but still sounded like it needed lifters when I was adjusting the distributor. I guess I moved it to far it kicked back hard on the starter.
Well adjust it and start it up and runs fine sounds strong, but liter noise still. Pop open the valve covers and I noticed no oil on the rocker arms. That's what let me to put a mechanical gauge on it. That's at 60 psi, so I don't feel like a bearing is wipped out, there wasn't any knocking when it was running.
Right now I'm debating on pulling the engine, pulling the cam, the pan checking the cam bearings. Then pulling the galley plugs and blowing it all out. Unless anyone has another idea I'm down to try out. It's a stock LO5 TBI 350, I put a 5.7 vortec factory roller cam, factory timing set, it's a TBI block that I was able to drill and tap the 3 bosses in the center for the lifter spider. I'm really trying to keep from pulling the engine because I'll drop more money in it, lol. I've already got a cam spec'd from crower that I haven't ordered yet,but new valve springs and retainers are in the garage.
