- Apr 16, 2005
- Sharon, SC
All you smart nerdy engineer types
@shawn @jeepinmatt @Fabrik8 @6BangBronk
and a whole bunch more I'm probably forgetting.
Intermittent problem has been stumping me for a few days now.
House has a septic tank and it utilizes an effluent pump to move contents up to drain field.
Pump is a standard 120V style with integrated cord plug and plugs into gfi receptacle located at man hole.
First problem arose when septic backed up found gfi tripped. Wouldn't reset instant tripped. Ran extension cord to another GFI recep (testing to see if that particular GFI recep was bad) and same results. Insta trip.
At this point suspecting failing pump or possible cord/connection leak to ground issue.
Tank was full and had to pump down to investigate furthr...well didnt have to but strongly preferred to.
Plugged extension cord into dedicated 20A recep that is not GFI and pump performed dazzlingly and quickly pumped tank down to appropriate level. Breaker never tripped, extension cord never got warm. Pump ran for 30 solid minutes maybe 45. (septic tank is waaaay over sized for house. dont ask. builder is a dumbass. for those who have been here you know...so not an indication of a clogged pump or under performing it was working that whole time) until float switch cut it off and everything was as it should be.
At this point not really questioning motor anymore. Just cord/connection.
Plug back up to gfi outlet and stay fine. Manually fill the tank until floats kick pump on, pump runs fine. Will keep up with hose indefinitely. GFI never trips. So its looking like everything works until water gets too high and then it shorted the connection out and would trip the gfi once water level got to appropriate height (below electrical connection) gfi would power pump just fine.
Replace the failed high level alarm found the first time this screwed up and life is good.
For 3 days.
Today high level alarm goes off again and again I have a tripped gfi. Same routine. Wont reset, use non gfi to pump water down. Resets fine and works with float switch.
Something isnt right.
Pulled pump. No signs of damage to cord.
Disassemble connections and megger test the cord. Cord is good.
Take stinky motor to motor shop friend he tests the motor and says it is shitty but performing flawlessly.
Now what....
Thoughts.
Its not "just" a bad gfi as when the water level is high the GFI wont reset.
No visible fault path to ground.
Motor is fine.
I'm seriously considering just ditching the GFI and using a standard outlet. Ye sits outdoors. Yes technically its a wet location. Its under a waterproof outlet cover and inside a fake rock cover. Its dry "enough" top work just dont tell the code enforcement boogey man. ...But that's not the "right" answer. And my damn anal retentive ass likes to do things right...only I dont know what right is here.
Tell me what I've missed.
Oh yeah. Just for S&Gs I megger'ed the wire between the breaker and the post at the manhole cover and its fine as well.
And I had motor shop friend test my megger and its good.
For 3 days.
Now what....
Thoughts.
Motor is fine.
