paradisePWoffrd
Recovering Project Junkie
- Nov 5, 2005
- Newton, NC
I have an 1.6 8v engine w/ stock distributor & Carb intake.
I was told that I need to get a Carb dizzy & housing but I figured I'd try to run it off the FI dizzy w/ an msd first.
Here's my setup:
Cps output to msd input.
msd power, ground, & ign strait to battery
Msd to + & - of the coil
Battery strait to starter.
battery ground to block/starter
Ign feed from dizzy to battery
ign ground to dizzy housing base to firewall
Problem:
The engine will crank & run but as soon as I let off power to the starter solenoid it dies. If I keep the starter engaged I can rev the motors & all just fine but let the starter off & it dies.
Thinking it might be the engine grounding through the starter but can't figure it out.
Any help would be great.
Ask away with the questions.
Here are the wiring diagrams Im going off of, and How I have it wired in.
Here's my setup:
Problem:
