loki_racer
- Sep 7, 2005
- Pittsburgh, PA
I'll do my best to describe the situation. My NP231 was rebuilt and had a SYE installed. The guy that did the install didn't cut down the shift rod so it wouldn't shift in to 4wd.
Today I removed the rear driveshaft. Removed the SYE housing from the transfer case. I cut the rod down so roughly one inch was exposed. Reinstalled the SYE housing and the rear driveshaft.
I pulled the XJ off the lift, and it drove fine in a straight line. However, it will not turn.
If I lift the front end off the ground, it will turn fine.
With the tcase in N and transmission in N, and the front end off the ground, I can not spin either of the front wheels forward, only in reverse. Maybe I didn't try hard enough, but I thought I should be able to freely spin the front wheels.
I'm fairly sure I have the shift level adjusted correctly. With the jeep in R or D, and the tcase in N, I can roll the jeep forward and backwards, which I assume means the tcase is in neutral.
With the little amount of steering that I could do, I never heard the locker unload.
Any ideas?
Any ideas?
