Gojira94
- Apr 29, 2022
- Clayton, NC
Craigslist find in Raleigh. POs were trying to take 2 MJs and make 1 good one. Originally a 2.5l / AX-5 / 2WD. At some point in the past it was 4.0 swapped and the harness swapped/ spliced, along with a Renix 429 ECM. Currently has an early era 2.5l bolted to the mounts with an AX-5 behind it. The 2.5 I say must be early era because it has provisions for a mechanical fuel pump on the passenger side of the block. It does have a single popper TBI intake on it right now. I briefly considered pulling the 2.5, light hone & rings, recondition the head, fix all the leaks. But to have any fun at all with it, I'd need to invest in converting the AX-5 to 4WD and end up with a weak combo not capable of doing much more than pulling itself up a steep hill.
Plan:
1) complete 95-99 drivetrain swap and run it on the Renix ECM.
2) (re)build fuel system, kind of suspect at the moment
2) acquire Dana 30 front axle, swap either front or rear carrier/ gears to match. Not 100% decided on ratio, I like 3.55 F/R but need to look at the AX-15 trans ratios again to see what makes the most sense.
Goal:
light duty factory-ish (to start) good, reliable runner 4WD for climbing/ hiking access roads on trips in western NC/ beyond.
Shopping list:
1)complete 4.0l / AX15 / NP231 drivetrain (acquired! Thanks, Shreddinlettuce!)
2)late HP Dana 30 from an XJ, front shaft (acquired from a 99 XJ, rebuilt/ installed 2024)
3)figure out rear DS length, cut & balance service (SYE installed, double cardan shaft ordered 2025)
Plan:
Goal:
Shopping list:
1)
2)
3)
