I knew I should have taken more pics of the "frame"! It seems like there WAS a clear seperation as you described. I wonder if it was just the '90-'95 that suffered from unibodyitis?
I'll be nearby this week and stop for another peek to insure this ain't a pig in a poke...
Thanks for the info!
Also, when the VIN was ran thru the decoder, it shows these were made in Canada. Not sure about that plays into the emissions game, but there was little evidence of smog crap on the engine (didn't pull the doghouse) and the exhaust (true duals with no crossover) had NO cats... single pipe of each manifold to cylindrical truck mufflers (staggered for space) run out the drivers side.
DMV (Insp. Greenwood) stated it could not be changed from a "bus" (still = property carrying vehicle just like "truck" or "van"), but could be tagged for any weight making it fine to tow with.
Doubtful I'll go this route, but the only other option is to outfit it as an RV (must have 4 of the following PERMANENTLY mounted: Sleeping Quarters, Self-contained Toilet, Cooking Facility, AC Power Connection/Minimum single recpt., Refrigerator, HVAC, Portable(potable?) Water Supply, or LP Gas Supply) and register as "Housecar"... even though it basically a "cubevan" once the seats are removed. He was unsure IF removing XX seats would change the need for a Class "C" CDL + Passenger endorsement and told me to call NCSHP...
NCSHP Motor Carrier Enforcement (Trooper Todd) stated that regardless of seat count, it would still be an "XX passenger bus" (since that's what it was originally built for) and would be at an officers discretion as to whether a typical Class "C" DL would be ticket-able or fine since the would only be seats for XX (any number UNDER 16 passengers
). He did say that in situations where used for towing, regardless of whether it was registered as a bus/truck/van... the typical wighted tag, under GVWR (10k#)/GCWR (26,001#)/GAWR(3900#F/7200#R), etc. would still suffice...
They both agreed the bottom line would what's printed on the VA title... both chassis VINs equate to:
CANADA
GM
TRUCK
9001-10,000 GVWR
FULL SIZE VAN
1 TON NOMINAL
HI-CUBE & CUTAWAY VAN
5.7L V8 4BBL
1986
ORION, MI or SCARBOROUGH, ON
So there is hope!
