They should both be the BIA Standard bolt pattern. Shaft length is important, yes, especially if the Force didn't come off another pontoon.
Things like gauges may trip you up though, and I don't know enough about either engine to know what that's going to look like. I doubt Mercury was using Smartcraft (CAN-based) gauges on a budget 50HP 2-stroke in 2004, so they're probably some semblance of analog gauges on your boat already. Same with that Force outboard probably.
There will likely be some rigging differences for steering, etc., that will have to be changed, and maybe larger fuel system/lines for the higher HP engine. Always, always, always, get an OEM primer bulb (any OEM brand is fine), because the aftermarket are garbage and not worth saving a few dollars for. May need a different throttle too because of the different brands.
Re-powers are not my field of expertise, I'm just throwing a few things out there.
