maddog411
- Mar 22, 2005
- Harrisburg, NC
I have a 2000 Dodge Ram 2500, 5.9 Gas V8, 4.10 gears, 35" tires, 5 speed manual for a tow rig.
Towed my other truck and trailer (maybe 7k) up I-77 thru Fancy Gap, VA a couple months ago. Fancy Gap is like 6% grade for 7 miles. Had plenty of power in 3rd but the temp got to the top of the normal range (about 240 degrees) and I had to downshift to 2nd.
Replaced the fan clutch and water pump after that.
Now I have a slide in truck camper that I took along with the trailer and other truck. The truck temp will go from 180 to 240 in about a 1 mile of fairly steep 9% grade and I have to pull over.
What's my problem? Should I dump the 35s and go to stock tires? Do a need a bigger radiator? Am I towing too much? This truck's tow rating is only like 8k with stock tires.
