thats $910 shipped and I have 2 on my shelf, but its cool my kid does not need to eat
ARB's and OX's are both sweet in my opinion.
ARB's absolutely need to be set up correctly or problems will arise. If the inside diff work is done clean and correctly then all you have to do is route the line out of harms way. Not that difficult. ARB's scream for attention to detail and they work flawlessly. the exception to his rule is toy 8'' and ford 9'' the design of these suck and although we have done many with no issues. they are very easy to screw up. and the 9 inch one has a weak ring in no matter which chromoly one you get.
A properly set-up ARB and mini compressor will not cycle for at a minimum of every 15 minutes. I have had them hold for as long as 40 minutes. they really don't leak unless there is a problem.
they are faster and easier to shift then an OX and switches can be mounted in very convienient places.
The OX is strong and simple, easier to set up. A properly routed cable is crucial if it gets anywhere near a heat source the sheath acts like heat shrink and siezes the cable. the cables are very stiff and not that easy to route and find a good spot for for easy shifting. Added to that like any cable it will want to sieze b/c of its nature, it needs to be oiled and used. in an offroad truck that sits alot the cables just get stuck cause they are not used alot. the cable mechanism i think is in harms way on the front of the cover.
If it were mine i would put an ARB in it. If someone gave me an ox i would use it versus selling it. and i would mount the shifter on th dash or somewhere high east to reach aroung the t-case shifter.
both are great products most issues that have arrised in use are iinstallation errors not the products fault. both require more attention to detail then a regular locker set-up. the ARB more so.
