Panhard Kits from Ruffstuff!
Dan Fredrickson
Sacramento
These are pretty straightforward and simple, all it takes is a quick look and you understand what you need to do and more importantly, what you need to order!
We start you with 54" of 1.5" x .25" wall DOM tubing, then we make you choose between an axle Centered or Offset Bracket, and finally you decide if it will mount on the frame Inside or Outside. The Brackets give you 5 choices of mounting height.
It comes with a set of our 7/8" 4130 Heat treated Heims with 9/16" Misalignment spacers and Hex Head weld bungs. The Hex Head bungs give you very fine adjustment easily. We also include the Grade 8 bolts in the correct length so you don't have to spend your day searching for them.
Here is a pic with one pair of bracket choices so you get an idea of how they look... But click on the link below to see all the other choices!
http://www.ruffstuffspecialties.com/catalog/panhardtrackbar.html
  • apics.ruffstuffspecialties.com_var_resizes_steering_panhard_20650f1887c95866b430f0c53c7f44bff2.jpg
2 Choices of bracket for each side, and 3 holes of adjust-ability on each one.
It makes such a big difference if your pan-hard is not setup to match the drag link, options let you get it right!
