mossyOblack
Member
- Nov 20, 2012
- hickory/newton
DIDN'T SEE A SERVICES SECTION SO I FIGURED THIS WAS THE BEST SPOT MODS PLEASE MOVE IF NOT CORRECT
Mossy
Newton nc
Pm or post here
98 xj 4.0
Ok hers the deal.. 98 xj had a blown motor.. Bought a 92 parts jeep and took out the motor.. Pretty much just the long block... Swapped it in the 98 with the intake manifold and sensors from the old 98 motor... Also used the cps from the 98... Motor starts idles then dies unless depressing the accelerator.. And even then it misses and back fires... I've changed plugs... Cps.. Injectors.. Wiring harness.. Map... And still the same issue.. I'm willing to pay upto 300 dollars in labor for a completed job.. I've had several mechanics come over and bs me.. Have me buy a ton of parts and still won't run.. Then they expect to be compensated... I will only pay for a COMPLETED job... I will buy parts.. Not interested in having it towed away to someone garage... I have a few tools here but you will need to bring your tools and diagnostic gear... please contact me asap like have her running before first snow...
The motor from the 92 was running just fine.. When it was pulled... It was pulled and dropped in the same day...
Mossy
Newton nc
Pm or post here
98 xj 4.0
