I replaced the pinion yoke on the front D60. I bought a regular socket (I forgot what size exactly) to fit the nut, it fit a 3/4" drive. The pinion nut is somewhat rounded by design (why, dunno). Socket works fine except when closer to the yoke, socket is too big and does not fit down in there. Did anyone else run into this problem. I need to get it tighter so I don't lose oil from my diff on inclines.
Is there a special pinion nut socket you need, or did you grind the regular socket, or did you use washers for spacers. Any help/advise would be appreciated. Thanks.
