for factory style L31 vortec heads, .480 lift is the max, when you go higher, the valve guides will need machining for clearance or the valvespring keepers will need to be changed. I'm going to assume this is for the 95 in your signature-what gears are you running? automatic or manual?? if automatic, what stall is your converter? also what is your intended use of the truck? a lot of times, people put in big hot-rod cams that sound cool, but fall on their face and finally get off their a$$ about 3000 rpms-not cool for a 4wd, look into a little more conservative cam with low & mid-range torque and it will have more usable power. this is especially true running a TBI setup, they're awesome for bottom end and mid range power(and easy to work on!) but for power much past 4000 rpms, they just run out of flow. with the TBI setup, plan on a custom chip if you go much past stock, the lopey cam profiles confuse the computer to no end.
