Any downside to going from Th700 to th400 for towing, other than losing overdrive?
I'll be towing a bumper-pull car trailer up to 7k gross, and 27ft Airstream that is 6-7k loaded.
I've got a 91 suburban that I'm fixing up to tow with. It has a tbi 350 that runs great. I've swapped in 8-lug axles with 3.73 gears. It has a 700r4 that was rebuilt at some point and works great, and a 241 t-case. Up to this point, the truck has only ever been used to tow 2-3k max
I need to replace the 241 tcase because one of the support rod bolt holes is cracked out. I think it got dropped when the trans was rebuilt. Plus it's leaking fluid between the trans and tcase, and at the front output, which would need to be fixed anyway. And I don't think this case has ever been rebuilt - it's got over 200k on it
I have a known good th400 and np241 from a 90 burb (thanks Qwk87Coupe). I was going to swap the input bearing from my 27-spline 241 into the replacement 32-spline t-case from the th400. That would let me keep the th700
But then I thought - why not replace the th700 with the th400? I won't use overdrive when towing anyway. Based on how I use my current tow rig, I'll probably only put 4k miles per year on it at the most, and the majority of it is towing (I daily drive an old accord, not the burb). We only use the burb for a few trips each year not towing (like to the OBX, or if we go to the mountains in the winter). When I'm not towing I run 35s on it, So I don't think I'll miss the overdrive.
I don't *think* I need the deeper first gear of the 700 when towing. In fact I don't like the wide 1-2 ratio spread of the 700 in my current tow rig when towing
I think I've talked myself into the th400, but am I overlooking anything that would be a drawback to the th400?
I'm trying to keep this low budget. I have no plans for a nv4500 or 4l80e. I already have both the 700 and 400, so I can choose between them.
Really just looking for input about the trans comparison, so please no comments about cooling, hitch, brake controller, springs, etc. I've got all that covered.
Thanks!
Richard
Thanks!
Richard
