RatLabGuy
- May 18, 2005
- Churchville, MD
I have a place in my basement where a vertical drain line, which was originally copper, has to immediately sweep into a horizontal PVC. It's cut really close to the subfloor so the pipe can remain above the joist bottoms the whole run.
Currently it is just a combo-wye held horizontally vertically with the top of female end of the sweep arm cut off, and joined to the copper with a rubber "multi-material" fitting. This is awkward b/c of the non-vertical angle of the PVC inside the rubber, but it does the job... sort of (see below)... but allows just barely meeting the minimum slope standard.
No rubber fitting in place:
and put back on.
What would be better way? Ideally to allow the end of that pipe to be higher up under the floor.
I've discovered, the hard way, that it is prone to getting backed up and blocking fluid flowing down. I suspect b/c the fitting slipped and the line sagged to too close to horizontal.
I will add a hangar for support, but surely there has to be a better way to connect this. I'm about 90% sure a 45 wye + 45 long sweep fitting is even taller. Short sweep 45 would not flow well (??).
and put back on.
