Positive Camber and Ilder Arm Questions
GimmieBoost
Lincolnton, NC
I have a '94 S-10 Blazer 4x4 with noticeable positive camber in the front. What causes a lot of postive camber? The outside of my front tires are starting to wear down more than the insides and I can't afford new tires.
I jacked the front of the truck up and when there's no load on the suspension the camber looks correct. There's also a very slight top to bottom play in the tire/wheel and a lot of side to side play. I know the idler arm is worn out again though. Are Moog suspension parts worth the extra money?
Any help will be greatly appreciated.
-Jesse
Moog is a good quality name just w/ better fit n function. Sounds like your problems are coming from bad hub bearings. This is very common in Chevy IFS.
Ball joints, gimme a yell if you need the tools tap or help with it.
