Charles Smith
smitty1371
- Sep 28, 2017
- ellerbe nc
Just put an intake exhaust gasket on a 98 tj with the 4.0. Took the power steering pump off and laid it to the side didn't crack open any lines. When I get it back together it's got this noise and the power steering barely works. Sounds like a grinding noise not the normal whine. I've jacked it up and cut the wheel side to side no noise till I hit the stops. Checked the fluid level it's perfect also there's no aeration in the fluid. I moved the wheel while touching the pump and I can't feel the noise in the pump I feel it in the pressure line when I turn the wheel. Am I missing something obvious? did a line collapse internally? hope y'all can help me.
