bluecrawler
Member
- Nov 30, 2006
- wilkesboro
Will a stock steering pump off a xj run a full hydro set up effectivly? (2inch bore double ended ram)
I ran that setup for a year. It moves the ram just fine but it's way too slow. Even with a 4.5 ci SCU I could turn the wheel faster than it could supply the fluid. If you want to do the full hydro piece by piece you'll get by with that pump but you'll eventually want to upgrade.Will a stock steering pump off a xj run a full hydro set up effectivly? (2inch bore double ended ram)
