TRD
- Aug 24, 2015
- Hermosa Beach
Hi NC4x4, I specialize in Pre-Tuned FOX shocks and deliver unbeatable performance right out of the box. Many common applications have already been documented, but we can also do unique builds with our AccuTune calculations.
The original Fox valving is very far off from what Off-Road trucks need so I re-valve every shock to match your application. Valving is backed by calculations and over 10 years of shock engineering & tuning experience.
Give me a call and I can help you choose the right shock, spring and valving combination. Don't forget that everything ships for free!
*Follow us on Instagram or Facebook to see what we're up to and all the vehicles we've tuned*
-Ryan
909-265-4443
Shop Fox Shocks Online:
Fox Air Bumps
Fox Air Shocks
Fox Bypass Shocks
Fox Coilover Shocks
Fox Smoothie Shocks
Testimonials:
-Ryan
909-265-4443
Fox Air Bumps
Fox Air Shocks
Fox Bypass Shocks
Fox Coilover Shocks
Fox Smoothie Shocks
Testimonials:
Chris said:Accutune Off-Road worked with me on the suspension package on my 4Runner. Ryan transformed the handling from your typical floppy rock crawler to greatly improved suspension that can effortlessly float over chop and rough terrain! Accutune supported with invaluable advice on shock selection, valving, suspension ratios, and bumpstop setup. The prices and service were unbeatable. I would not hesitate to return to Accutune Off-Road for any vehicle suspension needs.
Scott Windsor said:Ryan and Accutune have helped dial in the details on my Sway-A-Ways. I’m running 14in stroke, 2.5in diameter coil-overs on all 4 corners of my Truggy. He knows these shocks inside and out and helped me go through the process of valving and testing to find the best tune for my set-up. Not only in the field was he extremely knowledgeable and helpful, but he assisted me later by giving advice on steps to reach complete satisfaction with my set-up in the future. He can do more than just valve!
For future builds and friends of mine, I’d recommend giving Accutune a call to get your shocks as close to perfect out-of-the-box as you’re going to get.
Jim Feehan said:I have to say I never thought my 9,000lb truck could ever ride and handle so well. I’m running a 2001 Dodge Ram, Cummins diesel. Ryan set me up with a set of 2.5″ remote reservoirs on all four corners. I’m running the shocks only without the coilover springs with custom lift springs in the stock configuration.
I talked to a couple of the “other guys” (Dodge “specialists”) first and I wasn’t convinced they were listening to what I wanted from my truck.
Ryan gathered my data, listened to my needs and BAM! Spot on out of the box! I’m getting good dampening on big ruts and dips and am driving washboard roads at 60+ mph with no drama that I was stuck driving at 50mph or less before. Awesome highway and mountain twisties ride too, with no sway bars.
I have more projects in the wings. I’ll be back.
scottapher said:This thread is one of the main reasons behind me going with Ryan for my entire suspension needs...that and his customer service is top notch and his industry experience is obvious when you speak to him on the phone. Keep the tech coming.
mrqtipp said:I will say without a doubt that Ryans customer service is unmatched. Ryan went above and beyond what was expected of him and explained the inner workings of the coilovers. While I was installing the shocks I had a quick question about the relationship between the dual rate nut and the pocket slider for both sets so I put a quick call into him. Again he took the time to go through all the final adjustments for both sets of shocks. Then I learned I was talking to him while he was in Greece. Amazing service!!!!
