Pressing wheel bearings
whatpavment?
whitsett
In the end of a D 35. What do you guys use? Or what have you used? Last week I used a block of wood. Big damn mistake!! Pulled the shaft to day and the bearings had exploded:mad: Guess the block of wood was smaller than it looked. We all learn from are mistakes :shaking:
put the bearing in an old pot of oil. heat it up on the stove for about 30 min on med. heat. take the pot of oil/bearing to where you are installing the bearing. take out of oil and the bearing should slide right on. be quick cause you don't want the bearing to cool down while placing it properly.
good luck.
