Pressure washer advice
YotaOnRocks
Madison
Need one for washing atv's, trucks, parts and other miscellaneous stuff.
Any brands better than others?
Any certain psi or gpm to look for?
Honestly the gpm is key. I run pumps with 5.5 gpm 5000 psi for commercial work for what you wanna do 3.5 gpm would be good unless ya wanna do ya house then 3.5 will have ya there all week! We build our Machines 18hp Briggs engine with comet pumps! Landa is what the heated machines are and the cold ones are direct drive 18hp/comet to a unloader! North Star sucks btw! Lol even their Wands suck terribly!
I hear good things about karcher for home owner washers but no experience using!
If your not too concerned with pressure or mobility, my first washer was Electric. It did a good job, for it's size. Harbor Freight & others, still sell them for around $80. Generally have about 1200psi, with a 20-25' hose. My next one is a 6hp Honda engine with about 2700psi comet washer. Soap/chemical injector, [which no longer works] 25' hose & various tips. The manifold need to be resealed,but I still get by with it. Got some age on it. You can find similar washers on sale at Lowe's & HF, for between $250-300. Will cost me over $100, just to repair mine. But the Gasoline jobs, are bigger, need gas, & take longer to get out, hook up, & put away. it just depends on what you need. Not much to loose if you start with the Electric, & then decide you want more. I had an electric given to me that needs a small repair. If I can get that done, I'll probably use it more than the Honda!
Honda with a quality branded pump.
Unless you just want to secure the trigger on, then it can last. Unloader necessary for life of pump. Chinese pumps are 75 on eBay new. Lowe's, HD use the Chinese pumps, even with some of the Honda's.
Had a electric, it would take an hour to wash a dirty engine bay.
Borrowed a 13 hp Honda 3500 dual wand, would strip paint rapidly.
