Where can I get the oil that goes in the water pump on a pressure washer? Also, how often should I change it? Does the pump use the oil and I need to add some after use?
Check what model PUMP your machine has on it then find out what the manufacturer recommends. Do not over fill it because it can blow out seals and burn up the pump with the quickness.
