Preventative Maintenance
Bucket Puppy
Smithfield, NC
I have a 93 Jeep Cherokee. The Battery is dead due to a parasidic drain (haven't isolated that drain yet) it has been sitting for about 6ish months in the same spot and hasn't been started for about 2ish months (with a jump). Any hoo, that's just some back-up information, now to the real question...
I would like to do some preventative maintenance on the 180K engine to make this my DD, and because of that, I want to make sure I do this right. How do I approach a mechanic with my thoughts and at what price do I say "hey, that's a lot for some engine work, I think I'll just buy a new one (engine)"
Thanks in advance for the feedback
Undo the air filter box and pull the air filter out. If the filter is soaked in motor oil then your engine is wearing out (Blow-By). If there is just a tiny bit or none to be found anywhere then your rings are good and you probly have a pretty good motor.
For your question on price.....If you look on eBay, you can buy a remanufacured motor from $1400-$2000.
If it was me....
I would first check the air filter for oil. Say there was a little oil or none at all, i would drive it. I would drive it to O' Rielys and buy, New Spark plugs/Wires , Rotor cap/Button, Change the Oil/Filter and substitute 1 quart of Lucas Additive, PCV Valve, and flush the radiator. However it is your jeep so do what you wish with it.
^ x2 , except there is no PCV on a 4.0 Jeep motor.
Basic tune-up, fix any oil leaks, Full fluid/filter changes for every fluid in the jeep, including flushing the brake system. Then, drive it 'till it dies! (probably a good 50-100k+ more miles)
If you have the 4.0 then 180k means the motor is just getting broken in!! :lol::lol:
