Problem...
95Trooper
WNC
I went outside this morning and my clutch pedal was all the way to the floor in my Trooper. I picked it up and went to press on it and just gave it a little bit of pressure and it fell back to the floor. I don't understand because i was driving it the day before and it was fine. I basically have no clutch at all because of the way the pedal is doing. What do you think it could be? I'm guessing the slave cylinder went out but i guess that's a shot in the dark. Thanks for the help!
Check the fluid in your slave cylinder.. Im guessing a shitty hydraulic connection or line
Check the fluid in the clutch Master Cylinder too and look for leaks in the line . Sounds like you have lost your fluid and therefore pressure somehow.
Update: I've replaced the master cylinder and slave cylinder and we've bled the air out and still nothing...the clutch still falls to the floor and it has to be picked up by hand so i'm lost as to what could be the problem..any help would be appreciated
