Loganwayne
#BTL
- Feb 15, 2013
- Clyde, North Carolina
I've been looking at them and want to know if anyone has one or suggestions on what kind to buy. also have you saved any money by using one.
Is it programmable for several different times of the day? Is a single whole hose unit. I've looked at some that have separate controller for each zone of the house, that's not what I'm looking for I would have to redo duck workI just buy the cheaper honeywells that do the 5-2 program. It saved me money plus not having to mess with the air is nice. I like it colder when I sleep and I never have to touch the thing now.
Thanks for some reason I was hung up on the much more expensive units. How much a month did you save when you switched. During the winter i heat with wood when I'm home and cut my costs in half if I could cut even more off that I would be doing greatYeah, all of the ones I have got basically have a wake, go to work, get home from work, go to sleep (so 4 different time settings you can do). It may even have more but I always did 4. If you have a different schedule each day you should look at the 7 day programmables, and if on weekends they are different look at a 5-1-1
Shop Honeywell 5-2 Day Programmable Thermostat at Lowes.com That is the one I always bought. Had them in a couple houses now.
I have never had one that is dual zone so I am not sure how it can do dual zones.
This one is cheaper - Shop Honeywell 5-2 Day Programmable Thermostat at Lowes.com but not as many features
I have a Wifi enabled programmable one in my house. It wasn't much more than the non wifi one, and I like the fact that I can go away on vacation for a week, set the temperature in the house at 80+ and on the way home, switch it back on so the house is cool by the time I get home. It was pretty simple to install, too.
Beyond that I have nothing to add.
Model?
2 years ago when when I was looking for a new 'stat, it was either ~$60 for a pretty standard programmable one, or $200+ for anything that had cool features like this. But I'd assume things have changed since then.
I almost bought a Nest, but have read and heard directly about too many horror stories of their magic "updates" causing more problems (expenses) than it saved.
Model?
It's a Honeywell something-or-other. We bought it at Lowes or Home Depot (don't remember). It has an iPhone app that alerts you if it loses connection as well (power outage, etc).
Maybe this one? That is the one I am interested in. It just looks easier to see and use over the Nest.
We saved about 5% on electric by programming the tstat to our preferences.
I have a programmable Honeywell. It was on sale for $79 at lowes, typically $99.
I wired it into 24v power source.
The model it was replacing kept shutting the gas heat off as when it would kill the batteries. It started going through 3 aaa batteries a week. Probably could have just wired it into 24v power source as well, but I was fed up with it.
I can control it from my phone, but the nicer part is the email notifications for temp limits and communication failure.
You can preset upper and lower temp limits and if they are exceeded, it send you an email.
If the power goes out, and the server can't communicate with tstat for a selected duration, it sends you an email.
So in order for this to work, Honeywell must have a server that is logging your data. Do you have access to it? Historical data I mean. That could be quite useful.
And, do they have access to it to? It's even more useful to others... /tinfoilhat
By lowering the set point, you mean?
