What type of regulator is it, you are running engine oil though the regulator and not antifreeze? That does not sound right, I can't believe you oil would get hot enough.
your regulator/converter should have coolant running through it. Also make sure that it is in a location where water is forced to flow through it. If not, or it is mounted higher then the engine, coolant will not move and heat up the converter.
