Propane help
jlshermanjr
Member
brevard nc
A friend of mine just bought a buggy on propane. It ran fine until he changed the air filter and ever since he has to start it on ether. It runs fine as soon as it fires. I know nothing about propane, can someone offer some help?
Thanks, Johnny
New air filter too restrictive? Not letting enough air in at start up? After it starts and you have some vacuum going it sucks more air? Just a thought.
sounds like the diaphram is stopped up. I had the same problem with mine.
propane leaves a dirty film in the mixer,diapham and plunger,
take the bolts out of the top and slide out the plunger . Clean the diaphram,plunger spring with carb cleaner and re assemble,also there is an idle screw on some models,take it out(count the # of turns so you can put it back the same),clean it out and you should be good
