2020GLADIGATOR
- Sep 15, 2006
- Raleigh, nc
what are they and are they worth the money and trouble for an install?
I agree, however most would be replacing the entire light housing which has many LEDs in it. the only CON I know of is they are blindingly bright(brake lights) when you are following someone at night through the trails.They draw less power, so you can use them for longer without the engine running. They last longer than regular bulbs. The only drawback is since they are directional, they don't reflect off of the standard light housings. For instance, if you were to replace a tail light with an LED, it would appear dimmer than with the regular bulb without the aid of the reflector.
Has anyone seen the round led tail light with the yellow turn light on the bottem portion?
