mbalbritton
- Mar 22, 2005
- Lakeland, FL
Last Weekend I Swapped out my carb and Intake. went from a Holley 4 brrl Intake and Carb to the stock Cast Iron Intake and Carter 2 brrl. This is on a late 70's 318LA.
after swapping out, I'm now having what I've narrow do to, with 99% certainty, Vapor Lock. What I don't get is why it started now? Best I can come up with is that maybe I'm running leaner now with higher exhaust temps???? (Hard line runs close to headers)
Why I think it's Vapor lock? After sitting at a light or sitting still, It will go for a few seconds and then die. Check fuel lines between Pump and Carb and they are dry. The fuel hard line comes up the frame rail about an inch-inch and half away from the headers. Touch the hard line and it's pretty damn hot.
Last night it happened again, so I poured some water over the line where it was hot. it cooled the line off, I walked around and it fired up. As long as I keep my RPMS up while sitting still it won't do die on me. which leads me to the theory that I'm keeping the fuel flowing fast enough that it won't vaporize in the line.
but why now? Only thing I've done is swap the carb and intake. makes no sense.
anyone?
anyone?
