shocker998md
- Mar 6, 2007
- grantsboro nc
So I just picked up a truck from a member here. 1996 ram 2500 4x4 and this is my first dodge. After some Google foo it seems like all 2nd gen rams have front end issues.
I'm a stickler with my trucks and this loose front end is killing me. I had to get a state inspection and I have an alignment package with a shop so I got an alignment done, tires balanced and the inspection done while I was there. The front end is still loose and ive got a pretty good vibration throughout the entire truck at 45 mph and up. Heres the specs of the truck
1996 ram 2500
dana 60s with Spartan lockers, 4:10s and spyn tec hubs
315/75/16 mud tires, im pretty sure there maxis mudders, truck isn't in front of me right now
Unknown lift, looks like 3-4 inch blocks in the back. No spacers up front so im not really sure whats going on up there.
I just ordered new sway bar bushings, they were SHOT. I don't want to just dump money into parts, the tec that aligned it said I will need to look into the front left wheel bearing so that's a little concerning since the hubs were recently done. I will check it out when I pull the disks off to turn them and put new pads in. Im also going to try running a set of ATs that I have on my ford to see if it may just be the tires.
So I guess my questions would be, aside from having someone steer the front end and I look for slop, jack the front end and do some push pull and what not is there anything else to check out? I think after the swaybar rebuild and popping my ATs on it there will be a night and day difference. I guess I need to do some spyn tec reading on install and see what's going on in there.
On a good note im liking the truck a lot. 4:10s a 360 and a nv4500 is a pretty good combo!
1996 ram 2500
