Quick Fuel carbs by Left Eye Blind Racing
UTfball68
Granite Quarry
We are proud to announce our partnership with Quick Fuel carbs and the custom built Slayers now available on our website (these are not stock settings like most vendors you'll find). Need something bigger or want to go EFI, give us a call.
Quick Fuel Slayer (custom built)
And for those that prefer black...
Quick Fuel Slayer Black Diamond (custom built)
Custom built to your ride, from engine specs, to vehicle specs, transmission type to elevation - every carb and every setup is different - these carbs are built to your specifications so they're ready to bolt on and perform flawlessly with minimal, if any, tuning.
Slayer Series street carburetors are designed with many of the same innovations and features that are built into all QFT™ race-winning carburetors, including changeable air bleeds and power valve channel restrictions. It's designed with a secondary metering plate with changeable jets, and features all aluminum components for additional weight savings. All Slayer Series carburetors are equipped with universal throttle levers to accommodate Ford A/T kickdown, GM 700 R4 mounting holes, and ability to mount brackets for Chrysler vehicles. Slayer Series are available in 450, 600, and 750 cfm vacuum secondary models.
• Vacuum Secondaries
• Electric Choke
• Single Metering Block
• Secondary Metering Plate
• Cast Aluminum Throttle Body
• Single Sight Glass Windows
• Changeable Air Bleeds
• Adjustable Needles & Seats
• Notched Secondary Floats w/Jet Extensions
• Available In 3 CFM Sizes
You will receive an email from us after you place your order with a detailed spec sheet to get your carb built specifically for your vehicle - the more info you can provide the closer to bolt on and go we can get you. Because these are all custom built please allow up to one week for your new carb to ship. All carbs ship with a build sheet with all specs included.
Most commonly used applications are now on the website. If you need something else like an NHRA or derby spec'd carb, we can do that too, just give us a call if you don't see what you're looking for.
QFT
