uglyjeepoffroad
Registered Loser
- Mar 20, 2005
- Hickory, NC
After stripping the steering box input this past weekend I guess I should go ahead and install the drilled and tapped box I have. I am going to add a ram assist at the same time and was thinking of doing something a little different. There is a lot of room under my winch mount and I was thinking of running the ram from the passenger side framerail to the top of the pitman arm. I understand that this will transfer the stresses to the rod ends on my steering, but other than that, any reason I shouldn't? I am running heavy wall tie rod and draglink and 3/4 rod ends on all steering links. I was looking at a ram with swivel end mounts that could mount right to the top of the pitman arm with the 3/4 bolt running through the ram, through the pitman arm, and through the draglink rod end. I have a cross brace on the steering box, and a 3/8" plate box mount.
Am I reinventing the wheel? Should I just mount it on the axle and be done with it? I like the idea of tucking it up high and the lines being protected, but I don't want to cause stupid issues.
