Random items
MJnoc
Member
Lake Wylie
Just one of your general lurkers here getting rid of stuff. Free to good home (although I do accept bourbon donations) Located in Lake Wylie (29710) 30 min south of Charlotte
-JK Rampage trail view soft-top (900135) old and beat up but would keep the sun off your dome and mostly dry
-YJ inner 1/2 door panel
-old th350 or 700r4 adapter
-advanced adapter # 51-0405 From google:
  • Function: Converts the rear hex bolt pattern of 1996-and-newer 4L60E transmissions to match traditional 700R4/TH400-style transfer case spacing and length. [1]
  • VSS Integration: Includes a vehicle speed sensor (VSS) port and a clamp-on reluctor ring to generate a 40-pulse-per-output-shaft-revolution signal for electronic drivetrain control modules.
-(4) 37-12.5-R17 on old rubi rims 5 on 5. 3 hold air, one had a rip in one of the side lugs. Probably best as shop rollers
-SEN-01-4160 Cruise Speed Sensor
1970 Jeepster Commando Parts:
-Set of seats (2) Low backs and a rear fixed bench
I haven't pulled these yet but can if there's interest:
Drive train - 225 Dauntless V6 was running about 1-1/2 ago but been sitting in the garage ever since / t15 3 speed / Dana20
Axles - Dana 27 front and Dana 44 rear
If I can help coordinate anything, I'm close to the OP and have to get up with @frankenyoter at some point. Occasionally we will ride up towards hickory on Sundays or no telling where we'll end up. Let me know if I can help out with anything
