jbkelly0211
- Jul 20, 2010
- Charlotte
bought the truck a month ago for a hunting beat a round. 87 ranger 5spd 2.3l. quarter million miles. PO said it sat for 6 years, recently replaced gas tank, fuel filter, timing belt, and some other odds and ends. When I got it a month ago it had every code in the book. Replaced Coolant temp sens and that cleared a lot up. Replaced egr and egr position sensor, and that cleared the rest up. It has been running great for 3 weeks until yesterday, while at 70 mph on the interstate it starting bucking and lacking power. if I let off throttle it smoothed out, or pressed throttle harder it smoothed out. first thought was TPS, removed and tested and seems ok. Fuel pressure it good, 45psi with vac line off regulator, and 35 psi with vac line on. Fuel volume is good. No codes showing up. What I have not replaced are MAP, TPS, and IAC. I can crank truck and it idles good, will drive good until engine warms up. still idles good when warm, but shudders and lacks power while accelerating. removed vac line to MAP and it starts idling rough. removed harness to IAC and idle does not change. no change in driving with iac unplugged. Where should I troubleshoot next, I am almost out of ideas. TPS is discontinued from every vendor I have searched. would faulty IAC cause drivability issues like this? Cant find any vac leaks. When driving, first gear is ok, shift to second and it just starts shaking, push throttle to floor and it takes off like a bat out of hell. Any ideas????????
