Re-routing AC lines
livetorun
Mammary Enthusiast
Louisburg, NC
I have an 05 TJ and need to re route one of my AC lines. It was setup to run along the inner fender but my new fenders are now going to be custom and much higher and there will be little to no external fender. With the current setup, the AC line will be exposed and susceptible to damage. So to make a short story long, does anyone know of a shop that can make custom AC lines or maybe even make a hose that would do the trick? I can take pictures tonight if it would help in the visualization.
you can get the pressure tubing from any parts store and rent the flare tool youll gave to buy the tubing bender its like 5$so for around $12 you can route your pressure line however you want
Ok, so here is another stupid question. How do I get the lines apart? Is there a special tool for this? One side flares out into a bell shape and there is a band inside that looks like a spring.
