First of all, you need no more than a 2.5, 3" lift no matter what brand lift or fabricator you choose. Reason being you really don't need any more than that, even for 37s.
The common Company's that come to mind with high quality would be RockKrawler,Synergy,Currie.
The best deal out there IMO is the Rock Krawler Stock Mod system , 2.5 springs, front lowers, and Front track bar. Pair that with a set of qauluty shocks and it just plain works.
Other things to consider. With you Jk your 4.10 gears are very acceptable with 35s, 37,s you will need to regear. Less than 3 inch lift and you will not need a front driveshaft, more than that And your front driveshaft boot will bust and/ or will hit your exhaust. Go ahead and at least install gussets on your inner C,s on your front axle. You seem to wheel a lot so your ball joints on your front axle will soon be garbage, they have a nylon insert in them and do not last long after larger tires.
