MidwayJeremy
Member
- Feb 18, 2009
- Huntersville, NC
Putting a 14 bolt under my xj this weekend....what's the proper angle it has to be keep in mind I'm welding new brackets on and won't be able to sit it down with weight on axle....
So when it sitting normal ready to drive the angle of the pinion should be straight with driveshaft?
Also my jeep doesn't have a front axle so its on that jack stand lift.
I need to see what the angle would be if ya jacked up rear of Cherokee with 14 bolt under it and took a pic
If its off a couple degrees will that matter?
That depends...If you have a regular driveshaft with a u-joint at the transfer case, and a u-joint at the axle, you want the angles to match, so that it will cancel the vibrations out. Your pinion should be parallel to the transfercase output, not pointing at it.
A couple degrees isn't much, but if you can, err on the low side on the pinion. It is desirable to set the pinion up to a couple degrees lower than the transfer case angle, that way when you accelerate, it will twist the pinion upwards into the correct angle. If you had it too high, when you accelerate it would twist too high and cause vibrations then.If its off a couple degrees will that matter?
