rear brake line routing with 4-link
khwrx
Active Member
lincolnton nc
ok trying to get my rear buttoned up on my toyota after getting my 4 link installed. my question is how do you guys route the brake line to get to the rear axle? this is the first truck that i have put a 4-link on so im new to this.
I would run a hard line over the center of the axle (mounted/secured) and then have flex hose dropped to the housing and branched out to each wheel from there. This keeps things pretty tidy.
Nylon line from Speedway motors works killer. If it does get ripped off you can replace in in mins...... and its really cheap.
The way I'd expect to see on a high $$ buggy would be: short piece of flex line from frame to an upper 4-link bar. Hardline down the upper link, then another piece of flex line from the link to a tee on the axle tube (or individual lines if using individual cutting brakes).
I'm using a braided line from the frame, down an upper link, and to a tee on the axle itself.
Yes, run a flex line from the upper link crossmember, down the upper link to the axle, to a T on the axle then to the calipers.
I run the speedway motors plastic line and it is super easy to plumb and use.
