carthief007
Member
- Feb 21, 2009
- durham,nc
well i finally got time to start my rear disk conversion on my 97 f250...it wouldnt stop for with 37's on it.i ordered it thru gubni,thanks shawn...
time to tear down
heres the bracket mounted...perfect fit
but one problem before i went too far i tried slipping the rotor on...a lil too close,had to switch the bracket to the inside of the axle flange..
after i did that i tried again...a little too tight and the brake pad wouldnt fit...quick fix,removed bolts and put a washer between the bracket and the flange...all mounted now
this is a pic of the bracket mounted without the washers
here the caliper is mounted with the washers
alittle bit of anti sieze
2" spacers and all mounted
just gotta do the other side tomorrow and run the brake lines
time to tear down
